Hello. I’m trying to install savon to connect with a SOAP webservice. Savon requires nokogiri to be installed. In my external ruby 2.0 installation the correct platform is chosen for nokogiri (x86-mingw32) which has precompiled libraries. But Sketchup insists on getting the ‘ruby’ platform version which results in errors of not having the required build tools, but even if it did it wouldnt successfully compile (doesn’t compile in normal ruby200 installation). How can I make sketchup install the correct mingw32 version of nokogiri? The 64-bit 2014 SU installs the correct nokogiri-1.6.6.2-x64-mingw32… Really weird.
I was also told that bundler could help me fix this but I don’t understand how this can be accomplished inside sketchup as there’s no command line.
I managed to get the nokogiri-1.6.6.2-x86-mingw32 version to install by modifying rubygems.rb and platform.rb in the following places
# Array of platforms this RubyGems supports.
def self.platforms
@platforms ||= []
if @platforms.empty?
@platforms = ["x86-mingw32", Gem::Platform.local]
end
@platforms
end
def self.match(platform)
Gem.platforms.any? do |local_platform|
platform.nil? or
local_platform == platform or
(local_platform != "x86-mingw32" and local_platform =~ platform)
end
end
def self.new(arch) # :nodoc:
case arch
when Gem::Platform::CURRENT then
Gem::Platform.local
when "x86-mingw32", nil, '' then
"x86-mingw32"
else
super
end
end
Then the rest of the gems installed with an unknown prefix but I can require nokogiri and savon with no exceptions thrown. I would like to find a better solution as this is hacking with the SU files which is not that good to do.
When I thought I had at least solved my problem I tried to run a simple savon client that works perfectly in my ruby installation and I get many errors on Sketchup::Console, logger.rb and savon.rb
I tried the savon client on the ruby console, inside a ruby script, inside a UI.messagebox() with the same results in all. Please help me, I really need to fix it soon.
The Ruby Console is not a totally equivalent substitute for the standard output IO you get when running Ruby outside SketchUp. Not all of the things that a script might do to its standard output will work. This can interfere with Gems that try to manipulate the output IO. That appears to be what is happening in your case.
I commented out a line in options.rb of savon that had to with Logger and it doesnt throw an error now. Is it possible to install nokogiri and savon without hacking ruby files? Why does the 64bit version install the x64-mingw32 version of nokogiri but the 32bit ver of SU fails to do so for its x86 counterpart? Why can’t I force it to install a specific revision thru the Gem::install method? I see you have removed the third parameter *options which could be used to do something like --platform=x86-mingw32 maybe?
# == RubyGems Defaults, Packaging
# RubyGems defaults are stored in rubygems/defaults.rb. If you're packaging
# RubyGems or implementing Ruby you can change RubyGems' defaults.
# For RubyGems packagers, provide lib/rubygems/operating_system.rb and
# override any defaults from lib/rubygems/defaults.rb.
# For Ruby implementers, provide lib/rubygems/defaults/#{RUBY_ENGINE}.rb and
# If you need RubyGems to perform extra work on install or uninstall, your
# defaults override file can set pre and post install and uninstall hooks.
# See Gem::pre_install, Gem::pre_uninstall, Gem::post_install,
# Gem::post_uninstall.
None of the above has yet been done for SketchUp. Using gems with SketchUp is a new thing, less than 2 years old really.
NOWHERE does Trimble guarantee that gems that need DevKit can be compiled under SketchUp.
What some of us do is re-package gems after compiling, into SketchUp extension packages.
yes I meant x64 2015, sorry about that. Can you give me any hints about how to access bundler thru the ruby console or how to go about with that?
As for your second post, nokogiri doesnt even compile in vanilla ruby2.0 with devkit, they also say not to try to compile it in windows. What I’m saying is that sketchup should choose the correct x86-mingw32 or x64-mingw32 precompiled version depending on what version of sketchup is installed. As I have demonstrated above, it installs fine.
I’m certain the problem lies in sketchup not being able to put the correct variables @cpu and @os in Gem::Platform when you use 32-bit sketchup on 64-bit windows. When both are x64 it gives @cpu=x64 and @os=mingw32 so the correct nokogiri-x64-mingw32 gem gets installed. But on x86 SU on x64 w7 it gives
The problem for us is that much of the config of Ruby is done when it’s compiled. And getting the Ruby interpreter to function embedded inside a desktop application like SketchUp is very challenging. There is no clear API or documentation for Ruby to do so.
Dan, I struggle to find my notes right now, but did you know of a way to generate a full operating_system.rb to match a Ruby build?
Did anyone try with a custom operating_system.rb to see if that fixed the gem installation issues described in this topic?
Any idea how that is done? We don’t develop the Ruby interpreter, just try to hook it up to the host application - and the documentation for that is non-existent. That makes every issue like this a major time sink where we don’t have clear guidance to how it can be solved. All of this is unknown territory.
I’m far from advanced in Ruby but after a lot of searching I found it. The Gem::ConfigMap has an incorrect value for arch ("platform_specific" in the 32-bit SU version I have checked, might be for all 32-bit versions not sure) so everything that happens below it in platforms.rb is like it didn’t exist. ConfigMap takes its values from RbConfig::CONFIG
unless defined?(ConfigMap)
# Configuration settings from ::RbConfig
ConfigMap = Hash.new do |cm, key|
cm[key] = RbConfig::CONFIG[key.to_s]
end
else
RbConfigPriorities.each do |key|
ConfigMap[key.to_sym] = RbConfig::CONFIG[key]
end
end
the above is from compatibility.rb. Now the actual values that need to be changed reside in rbconfig.rb, and they are
sitearch doesnt have to be changed, it works even if it stays as it is, but the correct value is "i386-msvcrt". arch can be either "i386-mingw32" or "x86-mingw32", both work fine.
Gem.install 'mysql2'
[#<Gem::Specification:0x4954e6c mysql2-0.3.18-x86-mingw32>]
require 'mysql2'
DL is deprecated, please use Fiddle
true
client = Mysql2::Client.new(:host => "db4free.net", :username => "sepultribe", :password => "123456", :database => "testmysql2gem")
#<Mysql2::Client:0xb1a12f8 @read_timeout=nil, @query_options={:as=>:hash, :async=>false, :cast_booleans=>false, :symbolize_keys=>false, :database_timezone=>:local, :application_timezone=>nil, :cache_rows=>true, :connect_flags=>-2147442171, :cast=>true, :default_file=>nil, :default_group=>nil, :host=>"db4free.net", :username=>"sepultribe", :password=>"123456", :database=>"testmysql2gem"}>
results = client.query("SELECT COUNT(*) col FROM dual WHERE 1=0")
#<Mysql2::Result:0xb1a9f80 @query_options={:as=>:hash, :async=>false, :cast_booleans=>false, :symbolize_keys=>false, :database_timezone=>:local, :application_timezone=>nil, :cache_rows=>true, :connect_flags=>-2147442171, :cast=>true, :default_file=>nil, :default_group=>nil, :host=>"db4free.net", :username=>"sepultribe", :password=>"123456", :database=>"testmysql2gem"}>
results.each do |row|
# conveniently, row is a hash
# the keys are the fields, as you'd expect
# the values are pre-built ruby primitives mapped from their corresponding field types in MySQL
puts row["id"] # row["id"].class == Fixnum
if row["dne"] # non-existant hash entry is nil
puts row["dne"]
end
end
[{"col"=>0}]
from rbconfig.rb
# This file was created by mkconfig.rb when ruby was built.
so something goes wrong when u build ruby for 32-bit sketchups and this file gets the wrong values in those spots.
Not at this time. Basically it will be overriding selected methods from
“Tools/RubyStdLib/rubygems.rb”
and
“Tools/RubyStdLib/rubygems/defaults.rb”
Read the notes at the top of:
Notice at the top of this loader file:
require 'rbconfig'
module Gem
VERSION = '2.0.3'
end
# Must be first since it unloads the prelude from 1.9.2
require 'rubygems/compatibility'
require 'rubygems/defaults'
require 'rubygems/deprecate'
require 'rubygems/errors'
… then comes the important notes you should read, … then it defines module constants, arrays and module methods, some which likely need to be overridden,… then at the end of the loader file:
require 'rubygems/exceptions'
# REFACTOR: This should be pulled out into some kind of hacks file.
gem_preluded = Gem::GEM_PRELUDE_SUCKAGE and defined? Gem
unless gem_preluded then # TODO: remove guard after 1.9.2 dropped
begin
# Defaults the operating system (or packager) wants to provide for RubyGems.
require 'rubygems/defaults/operating_system'
rescue LoadError
end
if defined?(RUBY_ENGINE) then
begin
# Defaults the ruby implementation wants to provide for RubyGems
require "rubygems/defaults/#{RUBY_ENGINE}"
rescue LoadError
end
end
end
Note that RUBY_ENGINE is defined as "ruby", but the implementers file "rubygems/defaults/ruby.rb" does not yet exist.
It is the last rubygems configuration file loaded, before the loader modifies the global Kernel.require method.
I had already logged a couple of the methods that needed to be fixed but I think those were fixed and were pointing to the gem path strings.
Others that might need to be overridden, are: THESE ALL RETURN INCORRECT VALUES FOR THE SKETCHUP ENVIRONMENT
Gem::ruby (returns "/bin/ruby.exe" should it return the path to the loaded ruby interpreter ?)
Yea, this “something” is the tricky part to determine.
Maybe I can find some Ruby dev guru’s when I go to the Barcelona Ruby Conference later this year. Matz will be there - but I’m not sure if he’s that involved in the Windows builds. Maybesomeone related to the Ruby Windows Installer project.
Maybe some people from this forum could try and compile ruby the way u do to try and recreate the issue if u post the config file? Do u compile ruby on linux or on windows?
