Is that possible to edit dependent input items with Ruby in Sketchup?
for example, choose A in the first input field. the second input field can show different lists to be chosen. Or choose B in the first, the second input field will be deactivated.
Or could it be realized with WebDialog or SketchUp SDK ?
You need a WebDialog or HTMLdialog to achieve this.
But it’s a lot more complicated that writing a simple UI.inputbox() or two…
Otherwise, for very simple choices you could consider using two inputboxes.
So inputbox1 has a dropdown list and the user chooses option A and OKs, then inputbox2 opens automatically offering the dropdown subsidiary choices relevant to option A. If option B has no subsidiary choices then there is no inputbox2 needed, if the choices are different your inputbox2 uses a different dropdown list…
And perhaps I have to develop something using WebDialog. The Problem is if our insitute supply only SketchUp 8, in which only WebDialog is supported. If we develop a Plugin using WebDialog, can it runned by ohters who use new versions of SketchUp with HtmlDialog?
Later versions of SU run Web Dialogs fine. I have one (developed with huge help from Steve Baumgartner) which works perfectly fine in SU 2017, in which HTML Dialogs were introduced.
