How do I model this column? (from a Thomas Beeby library)
Please advise!
how do i model this column.skp (855.3 KB)
Please advise!
If I were modeling that I would create a cutter volume and array it around the corners of the column component and then use Subtract from the Solid Tools or better, Subtract from Eneroth Solid Tools or Difference from Bool Tools 2 to remove the bits I don’t want.
Like this.skp (821.5 KB)
BTW, I would suggest that you leave the model axes visible and keep your model closer to the origin. In my example I set up my column centered on the origin as this gives me an easy to idetify centerline for the column.
