Example:
Passing a webdialog reference into an observer, and
using that dialog reference to control the dialog’s visibility.
There is an issue that I left in, to show those learning the API. When the selection is changed from one item to another, it goes through an empty state, and the onBulkChange() callback gets called twice.
PassWebDialogRefToObserver.rb (4.4 KB)
# encoding: UTF-8
# Example: Passing a webdialog reference into an observer, and
# using that dialog reference to control the dialog's visibility.
module Author
module SomePlugin
extend self
@@dialog = nil unless defined?(@@dialog)
@@selection_spy = nil unless defined?(@@selection_spy)
@@opts = {
:dialog_title => "SelectionSwitch",
:preferences_key => Module.nesting[0].name.split('::').join('_')<<"_SelectionSwitch",
:scrollable => false,
:resizable => true,
:width => 150,
:height => 150,
:left => 500,
:top => 500,
:min_width => 150,
:min_height => 130,
:max_width => 200,
:max_height => 200
} unless defined?(@@opts)
class SelectionSpy < Sketchup::SelectionObserver
# Local constants:
WIN =( Sketchup.platform == :platform_win rescue RUBY_PLATFORM !~ /darwin/i )
def initialize(webdialog)
# This method is called in the newly instantiated instance,
# automatically by Ruby, just after the ::new() constructor
# has created the instance object. Ruby passes in along
# arguments that were given to the ::new() constructor.
# It does not matter what this method returns, the ::new()
# constructor always returns a reference to the new instance.
@webdialog = webdialog
# Initialize other instance variables here:
end ###
def show_my_dialog()
if @webdialog.visible?
@webdialog.bring_to_front
else
WIN ? @webdialog.show : @webdialog.show_modal
end ###
def my_dialog_is_open?()
UI.messagebox("The Webdialog is visible.")
return true
else
UI.messagebox("The Webdialog is not open!")
return false
end ###
### CALLBACK METHODS
def onSelectionBulkChange(selection)
if selection.size > 0
show_my_dialog() if ! my_dialog_is_open?
elsif selection.empty?
@webdialog.close() if my_dialog_is_open?
end ###
def onSelectionCleared(selection)
@webdialog.close()
end ###
end # class SelectionSpy
def dialog_init()
if @@dialog.nil? || ! @@dialog.is_a?(UI::WebDialog)
@@dialog = UI::WebDialog.new(@@opts)
@@dialog.add_action_callback("add_selection_spy") {
if @@selection_spy.is_a?(SelectionSpy)
Sketchup.active_model.selection.remove_observer(@@selection_spy)
else
@@selection_spy = SelectionSpy.new(@@dialog)
Sketchup.active_model.selection.add_observer(@@selection_spy)
@@dialog.add_action_callback("remove_selection_spy") {
if !@@selection_spy.nil?
@@dialog.set_html %q[
<!DOCTYPE html>
<html>
<head>
<meta name="MSThemeCompatible" content="yes">
<script>
function watch_selection() {
window.location.href="skp:add_selection_spy@"
function ignore_selection() {
window.location.href="skp:remove_selection_spy@"
</script>
<style>
body {
margin: 0px;
border: 0px;
padding: 0px;
margin-top: 16px;
margin-left: 16px;
margin-right: 16px;
div { width: 100%; margin-bottom: 16px; }
input { width: 100% }
</style>
</head>
<body>
<div>
<input type="button" onclick="watch_selection();" value=" Watch Selection ">
<div>
<input type="button" onclick="ignore_selection();" value=" Ignore Selection ">
</body>
</html>
end # if dialog init block
return @@dialog
end ### dialog_init()
def get_dialog()
@@dialog
end ###
# Call the dialog init method:
dialog_init().show()
end # this plugin module
end # toplevel namespace module
