Zoom Extents issue / question
76 View Road.skp (1.1 MB)
I hit Zoom Extents and it all went to a very small size. I cannot zoom out again. I should not have saved it and should have closed it and then reopened it (an recreated the work I did).
I have read the other Zoom Extents questions but still none the wise how to fix this issue.
Can somebody help please? Thank you.
Learn about Groups and Layers
Without texts and dimensions 76(SU2017).skp (1.2 MB)
Thank you very much. Yes I do need to learn more.
Is there any way to regain the dimensions and txt please?
Open your model, drag a selection box from left to right around the visible model (including the text) copy and paste into a new model.
With text and dimensions 76-2(SU2017).skp (465.6 KB)
Thank you so much!!
How did you manage to recover it?
I applied the advices from the other discussion (eneroth3’s codes) in which you wrote. But this is a temporary solution.
Normally it is good to learn how to draw correctly from the beginning. Group the raw geometry by type, then assign layers. After that you add texts and dimensions, on their own layers. And you also could use Scene for presentation.
Keep in mind that Layers do not separate geometry, they are just like tags.
Thank you
