Wrap-r plugin
i try to use free trial version of Wrap-r plugin. but view of mesh is terrible, i think using on same viw is impossible. how can i fix it? anyway?
You would be better off asking at Sketchucation.
Not sure if I understood the question, but you should definetly cut some seam to fix those UV.
It’s not “auto-magic” unwrap, you should define at least some cut in Sketchup (using the wrap-r seam maker tool), and maybe you can refine them another bit in Wrap-r itself.
You may also try to switch to LSCM mapping to see if it works better for your mesh and finally pack the UVs in a decent way to optimize texel density.
