Windowizer extension won't load in 2024
I just loaded 2024 and one of my essential plug-ins is Windowizer. Worked fine in 2023, but doesn’t seem to load because it is “unsigned”. Am I SOL or is there a work around that will allow me to use this and a few others that say “unsigned?”
are you sure that’s because they are unsigned ?
I have 5-6 extensions that are unsigned and they launch fine in sketchup24
I assume you get a message on startup ? that would instead mean that these extensions are not updated to the current ruby version.
The fact that the extension is unsigned doesn’t mean that doesn’t work with sketchup 2024.
No message on startup. I’ll check the other extensions, but Windowizer showed up after installing, but when clicked it doesn’t seem to run.
open the ruby console (extension / dev tools) then restart sketchup, and try to use windowizer. and see if something appears in the console.
Screenshot 2024-04-09 095731
Looking closer at all the rubies that are unsigned in that screen shot - they all came with windowizer in it’s zip file.
Agreed. I am still able to use the old free version of Profile Builder with SU Pro 2024. Working like a charm…
Windowizer has some problems with the new version of Ruby that v.2024 uses. I was able to fix the scripts I use with help form @DanRathbun but as it is a copyrighted script I cannot distribute it. Unfortunately the original author seems to have abandoned the extension.
Awe…that’s sad. It’s probably my primary plug-in for facades.
Maybe @DanRathbun could help you fix your copy independently?
It seems he isn’t accepting messages currently :disappointed_relieved:
If you posted the FULL error message in the Ruby Console it’d help find the issue…
Sorry, didn’t realize there was more…
c:/users/adehon/appdata/roaming/sketchup/sketchup 2024/sketchup/plugins/su_pcp/bin/32/SUPCP.so: warning: undefining the allocator of T_DATA class swig_runtime_data
Error: #<NameError: uninitialized constant Windowizer::Fixnum>
C:/Users/adehon/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/windowizer.rb:296:in `windowizer_settings’
C:/Users/adehon/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/windowizer.rb:207:in `activate’
C:/Users/adehon/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/windowizer.rb:108:in `initialize’
C:/Users/adehon/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/windowizer.rb:875:in `new’
C:/Users/adehon/AppData/Roaming/SketchUp/SketchUp 2024/SketchUp/Plugins/windowizer.rb:875:in `block (2 levels) in <top (required)>’
FYI: This warning applies to the Trimble Scan Essentials extension.
An maybe Dan won’t. Ie … how many users are out there?
Windowizer has a multitude of serious coding errors. Such as modifying core ruby and SketchUp API classes. It might be possible to have a script that overrides some of the errors, but other not.
I never have not gotten a clear answer whether the author really will fix this extension.
I myself do not have the latest version of it, so it makes it difficult for me to tell others what to fix.
I found Rick Wilson on LinkedIn…messaged him.
Hey Marvinadad did you have any luck getting windowizer to work in 2024? I am currently facing the same issue and its a tool I use a lot.
Please keep us updated as to whether or not Rick is able and willing to update his great script for 2024. It’s one of the main scripts I use for so many things. Thanks for any update.
He said he was going to check it out and get back to me. I need to follow up with him.
