I would really like to add window frames to all the windows in the building at once. But I have some problems.
- the first problem is that the window frame between two glass panes will get a double frame.
- The second problem is how to fix the diagonal connected windows.
- Third problem are the curved windows and window frames.
- 4th problem is materialisation: glass panes with other colour window frames.
Extension and tools I currently use/tried:
- Normal offset
- SJ frame generator
- Tools on Surface
- JointPushPull
- Curviloft or ‘push line’ extension to make the curved faces
Materials: When i use SJ frame generator, it makes all the frames groups, this works really well with materialisation.
In the end, the tool I need is an offset tool at all faces at once (ignoring smooth lines) which halves the offset between two faces. The created faces should be groups or at least be separated from the first existing faces.
Or maybe a different method which works.
Current model: These are all windows i would like to make the window frames. The outer edges of the current faces are will be the outer edge of the windows frames
What i want, all at once:
Extension SJ Frame Generator: gives me double the frame with in between two windows. Curved windows has double with and gaps.
Extension Tools on surface: works with curved faces, but still doesnt give me the inner frames.
