Why Transparency
I am developing a model and it appears that some surfaces are transparent when I really do not want them to be. I need to understand what I am doing wrong.
As you look at the image, notice that the text at the bottom of the heart as actually on the back side (this is a 3D model) so I should not be able to see that text when viewing from the top. If I look from the other side (bottom) you can see the text that is on the top face.
I have also been having s little bit of a problem placing text on the top and bottom surfaces.
Looks like you have back edges on (I can see dashed line on the top of the heart) - type K to turn off back edges
I do not think I do but how do I determine that?
BTW: TIG on SketchUcation told me to hit the K key which solved the problem.
@KyleB told you the same thing!
If pressing k makes it go away, that proves you have back edges turned on..
Yes, when I went and looked at things again, back edges were turned on.
k is the keyboard shortcut, otherwise it can be found in the edge styles.
GIF 24-02-2026 9-15-19 PM
@Box Thanks a lot sir. :grinning_face:
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
