Why my lines don't make a face?
I don’t know what I’m doing wrong!!!
It seems that all the lines are in the same plane.
Share the .skp file so we can see exactly what you’ve got.
The plug-in edge tools can show you if there are gaps, you can also draw lines and see what zones create faces and find the zone where the gap is.
Terreno 01.skp (232.9 KB)
I tried with the edge tool and is not working :frowning:
I downloaded the plugin and it tells me it doesn’t have any gaps, I dont know what I´m doing wrong
It’s not flat enough. Notice the Z-values of the coordinates.
Move the high corners down or the low ones up. Here I moved the two high corners down and the face fills when I trace an edge.
face
Terreno 01 fixed.skp (232.3 KB)
Is this a situation where it would be best to use the rectangle tool, draw the shape on the face of the rectangle, and then erase the boundaries of the rectangle afterwards?
It would be easier if just starting but it is simple enough to move the two nearest corners vertically to the same height as the rest of them.
Thanks, Dave.
Thanks for the help!!!
