Why is there Diffuse color on exported elements?
I am exporting elements from Sketchup into obj format.
I have found that elements that have textures when exported have diffuse color that is not white.
The diffuse color is almost similar to texture color.
How can I avoid this unnecessary diffuse color through ruby API calls?
No control over that via the API.
I’m not entirely clear what the issue is though? What is causing problem where/when?
What is expected results?
For e.g when you export Sofa - attached model.
Following is the generated material file
newmtl _
Ka 0.000000 0.000000 0.000000
Kd 0.898039 0.878431 0.721569
Ks 0.330000 0.330000 0.330000
map_Kd Sofa/_.jpg
newmtl BackColor
Kd 0.643137 0.698039 0.733333
newmtl FrontColor
Kd 1.000000 1.000000 1.000000
As you can see material named “_” has diffuse color(Kd) : Kd 0.898039 0.878431 0.721569.
Why the diffuse color is not white?
Sofa.skp (208.0 KB)
if you interrogate your material in SU is the ‘average_color’ being used for diffuse?
    MATERIAL:
    display_name       => Material
    materialType       => 1
    alpha              => 1.0
    use_alpha?         => false
    colorize_deltas    => [0.0, 0.0, 0.0]
    colorize_type      => 0
    texture            => #<Sketchup::Texture:0x00007f9d9b959c60>
    owner_type         => 0
    name               => Material
    color              => [229, 224, 184, 255]
    TEXTURE:
    width              => 6.400000000000001
    height             => 4.0
    valid?             => true
    image_rep          => #<Sketchup::ImageRep:0x00007f9d98a86cd0>
    image_width        => 650
    image_height       => 650
    filename           => C:\Users\Stonex\Downloads\Sofa2.jpg
    average_color      => [229, 224, 184, 255]
john
Got it. In that case a can just avoid color where there is texture in my renderings.
