Re: Why does not Layout retain the printer settings when it is applied.
This should be the default printer setting when you open up the file next time you want to print. It does with every other program I use
Export a PDF and print that instead.
It’s been discussed on here before - it’s infuriating.
I only print to a PDF. If I can avoid it I never print
Axys,
So rather than a make a comment like that, you might be more helpful and direct me to the information.
Ian Cleland
SUCH Developments
