LO 2024
without opening your file it’s hard to say. two things comes to my mind :
- your background in sketchup isn’t white. not completely. and/or you didn’t remove background in layout
- your section plans are visible (in SU) ?
if it’s not that, can you share your file please ?
Is that what it looks like in LO or in the PDF export?
What are your settings for working and output quality? File>Document Setup>Rendering
The background in your SKP style is not white…
Edit the style, change to white:
Be sure to update, then save the SKP file and update in LO
Thanks for your help.
No problem.
Please check the proper post for the solution.
ha ! classic
Nailed it.
when I need white I always switch to RGB and push to 255.
the wheel is nice and all, but it’s the best way to go off white.
been there. done that. emptied a black cartridge printing light gray backgrounds.
FWIW, the description of the style tells you there’s a gray background.
