Hi! When I import the model from the 3D warehouse to my working project file black outlines appears, but when I import it to a new file it appears correctly.
I tried to change the style, but it doesn’t work. Anyone know how to resolve this? Thank you!
If you insert the compont into your existing file, the component will be displayed with your current style. If you downlad the component and open it on its own, it will show with the style the author had selected when they uploaded it.
Share your .skp file showing the bed so we can see better what you’ve got.
I got called away with a student. Looks like Riley got you sorted out.
FWIW, if this bed is part of a larger model. you might want to go through it and give it a bit of a trim. 12 Mb for just a bed seems a bit excessive unless it’s your entire project.
Purging unused elements is a good thing but you should also look at some of the used dteail. For example the headboard on this bed accounts for about 43% of the entire file size. It’s a creazy amount of geometry for what it is; especially considering that most of it is hidden by the pillows. You could replace it with a single face and a texture which would greatly help to reduce the file size.
