Where did Aerilius Attribute Inspector go?
Just realized that the Attribute Inspector extension by @Aerilius is gone from the warehouse and I don’t see it on SketchUcation either. Anyone know why it’s gone or if it’s returning? Any good alternatives for DC attribute inspecting and editing out there?
His code repository is still on GitHub. The last activity was 5 months ago.
Note that v3.0.4 has a blank window problem in SU2024.
You’ll need to rollback to v3.0.3, which is no longer posted in the repository.
ae_attribute_inspector_3.0.3.rbz (172.7 KB)
@Aerilius You should always supply at least one previous version in case the latest has catastrophic issues so users can rollback.
Amazing, thanks Dan! I feel like you should have a superhero suit of some sort, you come to the rescue of folks in need around here so often. :man_superhero: But what would your name be…?
Um … I dunno. “Geekazoid” ?
SuperClass? Hashman? I’ll work on it… :grin:
Bad guy names are easier: The Iterator, goes around causing endless loops…
Possible Geekaziod Rangers member names:
The Bug Splatter
Looper
Blue Screen
Issue Tracker
Error Code
Dr Algorithm
Syntax
Interface
Wrath Code
Hacker
Method Man
The Flow Charter
Not a definitive list… but a topic that clearly needs more attention!
Recently there was a similar topic on the forum Aerilius Attribute Inspector not working in 2024 - #7 by tomboul26
It seems that the author found a solution to the problem, but I did not check)
