Hi there
Is there an option to set the charset sketchup is supposed to use?
Thanks
It is good to textually describe the problem or what you want to achieve. Your screenshot shows the Credits section of Model Info with the author name “Sébastien” instead of probably “Sébastien”. This is a bug and something you neither should be forced to nor want to configure on your own.
The question is where this comes from (and a screenshot can’t tell that).
Thanks you for your help.
I’m the actual author of this Sketch. My user name on 3D warehouse is correct (although I needed to change it manually because I had the same problem)
Anywhere else in the software the Charest seems to be correctly set, but I can’t find where to manually set my username in Sketchup
It could be that there was a problem in the transition from the old to the new 3D Warehouse (2014).
It could be that the username is saved to the database in the wrong encoding.
It could be that the username was transfered to the SketchUp application in the wrong encoding when you logged first in and claimed credit. Then it was stored in the model (where it is not updated when you change it in your 3DWH profile).
