When EXTRUDE is performed, a transparent body is created without the ability to paint
I have a profile section . The general size is 44 x 44 cm, where the width of the section of the profile is 1 cm.
The problem is that when you extrude the surface it becomes transparent and you can’t paint it .
What caused it and how can it be treated?
Attached is a screenshot before and after the Extrude
Thank you very much
Unfortunately you didn’t… but even better if you also share your model.
What is the "extrude " exactly means?
Which tool are you using: Push/Pull or Follow Me or Extension (plugin)?
simple Push/Pull !
I am tryng to upload a JPG but I get a system error masage
Do you have a screenshot of that message? :stuck_out_tongue_winking_eye: :peace_symbol:
Normally you just need to drag and drop the file into a field where you are typing to post you answer…
There is still an error message when I try to upload the screenshot.
I tried to just push/pull on something else and saw that a body was created with shading and it seems to me that the file is probably damaged.
I opened a new file and transferred the previous file to it in the Import operation and now everything is fine
Thank you very much for trying to help
Really appreciate it
