I created a plot map and I have to put the scale that I used on it. I would like to know the scale that Sketchup for Web uses by default. I have the measurement set for 1/2" length and 1/64 precision, if that information helps.
SketchUp is a 3D design environment, all geometry in intended to be modeled at actual size. There is no scale. Scale comes into play when you create a 2D image of your object, then you must have a scale as the actual sizes of your object most likely won’t fit on your piece of paper.
