Can someone tell me what am I doing wrong with Push/Pull? I connect to a corner Draw to a midpoint and try to push in a rabbit, but it leaves a overhang. If I come from the top and push down, it makes a trough? Any thoughts
Most likely something is not square. Can you share your .skp file so we can look? Otherwise we will be guessing at best.
You have a component for the top surface and the miter slot but the geometry underneath is separate. He I’ve moved the component up.
Probably you just need to explode the component so all of the geometry is combined. After yu’ve finished detailing it, select all of the geometry that makes up the “board” and create the component.
Here I’ve exploded the component. I also then fixed the slot.
Great, I figured I did something wrong. I appreciate your help guys!
