Hi everyone, I’ve got an HtmlDialog
feature for which I’d like to offer a WebDialog
fallback, but I’m having a little trouble with what seems to be different behavior between the two.
The dialog is created with a line that expects parameters returned, like this:
params = message_box(title, key, JSON.generate(hash))
My message_box()
method sets up the dialog properties, accounts for differences between HtmlDialog
and WebDialog
, and adds a couple of callbacks. (I’m leaving out those differences in what I’ve pasted here, for now, in favor of the original method, which is clearer for now.) With HtmlDialog
, it returns a params
variable to the calling method when the dialog is closed. In other words, it doesn’t execute the last parts of the method until after the dialog has closed. But, with WebDialog
, this fires out of sequence: the message_box()
method goes right on down to the bottom, returns something to the calling method, and only executes the callbacks afterwards.
Somehow, I’m trying to get this method to return a params value with WebDialog
as well, but no matter what I try, the method always returns something too soon, before we are ready with params from the callback… Trying an explicit return params
from the callback gives me a LocalJumpError
, for example. Anyone have any ideas?
Many thanks in advance!
(I should note also that the method def below doesn’t reflect other changes I’ve made to accommodate WebDialog
, such as that set_can_close
is not called, etc.)
def self.message_box(title, key, json)
loaded_json = JSON.load(json)
width = Global::get_messagebox_width
height = Global::get_messagebox_height
html_path = File.join(File.expand_path(File.dirname(__FILE__)), '/html/messagebox.html')
@messagebox = UI::HtmlDialog.new({
:dialog_title => title,
:preferences_key => key,
:scrollable => false,
:resizable => false,
:width => width,
:height => height,
:center => true,
:min_width => width,
:min_height => height,
:max_width => width,
:max_height => height,
:style => UI::HtmlDialog::STYLE_DIALOG
@messagebox.set_file(html_path)
params = nil
@messagebox.set_size(width, height)
@messagebox.add_action_callback("dialogReady") { |wd, param|
@messagebox.execute_script('skpCallbackReceived()')
js_command = 'setup('+ json.to_s + ')'
@messagebox.execute_script(js_command)
params = param.split(' ')
adjust_dialog_size(@messagebox, params[0].to_i, params[1].to_i, params[2].to_i)
@messagebox.add_action_callback("buttonResponse") { |wd, param|
@messagebox.set_can_close { true }
@messagebox.close
@messagebox.center
@messagebox.show_modal
# we end up here on when the window closes..
return params
end
