Is there a way to get dims to remain visible from more perspectives/ angles?
Here is a common but curious case where dims are on top of each other, but only one shows…
Thanks!
Thanks!
Thanks!
Those should all be unchecked correct?
(Same result using both settings alas.)
Yes. Those should both be unchecked. The only dimensions you wouldn’t see would be those that you’ve placed such that they would be occluded by the model.
Placing the dimensions correctly would prevent that problem though.
