Wall shingle pattern fill for Layout
Where can I find a Layout pattern fill for typical cedar wall shingles?
I did a search and took the first hit I got which was this. I wasn’t picky since this is just for an example. There are lots of images out there that could be used for fills in LO.
Thanks Dave, I don’t know why this has been a mental block for me…I just now learned how and where to add a pattern to my materials resources folder with the “package contents” of the application.
You’re welcome. FWIW, you can add custom fill patterns to the document and add custom collection folders right in the Fill Pattern window via the drop down.
Here’s a follow-up question: Is it possible to have transparent pattern fills? I like to render my models with shadow in Layout, but adding a typical fill obscures the pattern.
It doesn’t appear that pattern fills can be made transparent. You could, however, make the pattern PNG with transparency and insert it as an image. Then draw a shape to use as a clipping mask on the image. As an example I traced the leg to get the shape of the clipping mask here.
Same shingle image from before but now with transparency. The forum software might convert this to a JPG in which case the transparency would be lost.
I appreciate your suggestion but that seems like more work than is justified…I’ll just try to keep patterns in anon-shadowed area! Thank again!
If you are adding fill patterns in LayOut you still have to draw the shape for it to fill. It’s really no more difficult to use a clipping mask with the image and the shape.
Maybe not the answer you were looking for, but why not add the texture to the SketchUp model? If you just want it for a specific LO scene, what I often do is put something on a dedicated tag for that scene so it only shows up there. That way it receives the shadow and self corrects if you go back and change the model, like moving the window over 8".
Well, I use texture in my models all of the time, but when I want to print in black and white textures do not translate; wish they did. Is there a way to achieve that goal, textures in B & W?
You could use an image like the one I shared as a texture in SketchUp.
