Is there a way to modify the sensitivity of the walk tool, other than with the modifier ctrl-key?
I’m modelling in SU2022 pro and my native walk tool is overly sensitive in walking forward/backward. Sideways is ok. Using the modifier ctrl-key makes the problem even worse.
The speed of the movement is determined by the distance between the + icon on the screen and the cursor. Keeping the cursor close to the + is the only way to keep it moving slowly. The modifier key is for Run so probably not what you want if you are moving too quickly as it is. There’s no settings in Preferences to change this.
