Vray mesh to normal geometry
Hi, I’m Raul Cabral.
So, I’m having a hard time to explode a Vray mesh into a normal geometry with materials applied. To be specific I need to modify the mesh geometry.
As you see in this image, I need to cut the man’s feet, that is out of the car.
There’s anyone here that can help me?
The VRay model is a proxy, no?
I don’t believe you can edit the geometry in them.
@bmike is right…the actual geometry is being loaded outside of SketchUp and cannot be edited directly. Try using a section plane instead to ‘clip’ his feet out. Be sure to group the plane and person together so that the section only affects him and not the whole model :wink:
Ahhh you beat me to it. Just tried that and it worked.
Thank you Eric, helped me out a lot!
You gotta be quick around here! JK but I had never tried this and figured it should work so was pleased to see it had.
