Is there any way to make Sketchup (1) display object dimensions on-screen all the time, like in a status bar or a pop-up window, and (2) change those dimensions by typing in exact numbers, WITHOUT having to drag/resize it?
In other words, I’m used to the AutoCAD & CorelDRAW approach (where you can draw a basic shape and then type in the dimensions into the property bar), and I’m having a VERY hard time with the “non-exact” UI approach that Sketchup has. Like, why do I need to drag an object on screen and then “blindly” type in dimensions & hope it works? Why can’t I have an EXACT, DEFINITE property bar for it?
Any advice? Options / configuration, extensions, custom code?
Thank you!
