Visibility of co-planer edges in Layout
When two edges are in the same place in the SU model, except one is behind the other, the viewport in LO should give priority to the edge that is in FRONT of the other one. That is to say, if I change the line type in LO for the object that is behind to a dashed line, it shouldn’t show the dashes where the edges of the two objects line up.
For example, in the image below I changed the line style for the tag controlling the gray walls to dashed. Those walls are behind/below the beige-ish walls which have a solid line style, or should. The obvious workaround is to stack viewports, but shouldn’t that be unnecessary? I don’t know about y’all, but I like fewer viewports to manage!
