Hi Friends,
Sorry my bad english!
In my project, I used an image for environment and the result is that my render is very clear! I tried edit values and the image in environment it is not realistic.
Thanks!
Hi Friends,
Thanks!
Do you mean the background has gone a bit foggy because you have edited values on environment settings?
Why don’t you load up default settings and work your way to re-apply the image onto the environment settings?
Hi Joseph,
Thanks for your help.
My process is: In Environment I up the image in GI (Skylight) and in Reflection refraction (background). In the UVW Type I use UVWGenEnvironment.
The values are 5,0. I don’t understand the “fog” aspect in the background.
My image is JPG file.
I do not change any other value.
Thanks!
Sorry, I am unable to provide why it can be having fog effect.
would you be able to share your file and your jpg you are using as your background?
