I’m just about finished designing the main air extactor. The first thing I had to do was learn what an air extractor is and why is it there. There are three of these in the engine room; a large Main Air Extractor (MAE) and two auxiliary air extractors. The main is pulling vacuum from the main condenser and the auxiliaries are pulling vacuum from the turbogenerators condensers. They look the same except for their size. For steam turbines to function effectively, the exhaust steam must be drawn out of the machine into vacuum. The steam is depleted to a point where it would lose all forward momentum without the vacuum. There is some negative pressure created just by condensing the volume of steam to water in the condenser, but it’s not enough since there is leakage in the system.
The main air extractor works on Benoulli’s principle that pressure on a surface is reduced inversely proportional to the speed of a gas over the surface. 600psi steam is applied to a venturi where the suction line is attached to the gases in the condenser further reducing its internal pressure. Very high vacuums can be drawn this way. The MAE outputs the extracted air to atmosphere and any condensed feedwater is fed back to the main condenser hot well. Further feedwater prep is done in the firerooms and is not part of the model. There is also condenser coolant water in and out that is used in the internal condensers in the MAE. It’s really a complicated piece of equipment.
I am totally guessing exactly where the piping goes for this thing. Here’s the a picture showing why that is.
Given that, here’s a rendering showing it in place on the upper level. I don’t have any detailed drawings about the MAE or its foundation. I have four images inclduing these two.
I’ve got requests into Ryan asking for more information about this. Regardless, I’ll do something respectable.
I printed the lube hand wheels separately and applied them with 0.025" phos-bronze wire. Look much better than the partially deforemed ones that were printed on the part.
I removed all the tall angle supports from the MRG frame to accept the smaller version that is now printed integral with the Lube Pumps. After prepaing the surfaces I used the rubber-infused CA to adhere the electic lube pump. The modified (fixed) steam lube pump will be printed along with the MAE today or tomorrow. The electric motor came out beautifully with the cooling ribs perfectly defined.
While the steam pump print has some errors there were some spectacular print features that blew me away! This is an extreme closeup of a spring that I downloaded from the SketchUp 3D Warehouse. I reduced its size, but did nothing else to it when I determined it was printable. It has some loops at the end.
Here it is on the pump.
And if you look closely, the printer reproduced those loops. This isn’t supposed to happen… or at least it didn’t happen with previous versions of the LCD resin printers. With the naked eye, those parts are tiny. They’re 0.010" or less.
I printed more ladders. I found that the short ones were also with full treads and I needed a ladder with 9 rungs.
Getting good at making ladders. Till next time…
