# Using Trim results in non solid group
**URL:** <https://forums.sketchup.com/t/using-trim-results-in-non-solid-group/99707>\
**Category:** Pro\
**Created:** [July 26, 2019, 3:56pm UTC](https://forums.sketchup.com/t/using-trim-results-in-non-solid-group/99707 "2019-07-26T15:56:00Z")\
**Showing post:** 4
**Author:** ![DaveR](https://sea2.discourse-cdn.com/sketchup/user_avatar/forums.sketchup.com/daver/32/7601_2.png) [@DaveR](https://forums.sketchup.com/u/DaveR)\
**Post date:** [July 26, 2019, 4:14pm UTC](https://forums.sketchup.com/t/using-trim-results-in-non-solid-group/99707/4 "2019-07-26T16:14:50Z")
You’re running into the tiny faces issue.
 ![Screenshot%20-%207_26_2019%20%2C%2011_11_21%20AM](https://global.discourse-cdn.com/sketchup/original/3X/5/d/5d98aa0f06853537108ae11c027ad6ba6281db4f.png)
You could avoid that with the native Trim tool by scaling the model up by a factor of 100 or 1000 before running Trim and then scaling back down afterward. Or, you could make the block a component instead, use the [Dave method](https://forums.sketchup.com/t/the-dave-method/49720) to scale a copy of the block and cylinder up, use Trim from Eneroth Solid Tools and delete the large copies when finished.
A third option would be to move the cylinder farther into the block, run Trim and use Push/Pull to pull the face at the bottom of the hole back out to the outer surface of the block.
 ![trim](https://global.discourse-cdn.com/sketchup/original/3X/7/1/71f7584a888480773e2a4372134d1a9b5360a8fa.gif)
_[View the full topic](https://forums.sketchup.com/t/using-trim-results-in-non-solid-group/99707)._
