Using function result as attribute name
Hi!
Sorry if my question is silly, but I’ve just began learning dynamics components!
So in my child component I want to have access to one of my parent components. I want to choose it, depending on witch Copy of my child am I.
so for copy 0 I want to get attribute called prefix_0, for copy 1 I want to get attribute with name prefix_1 etc.
I tried something like that: =parent!concatenate("prefix_", copy) apparently it does not work here.
So the question is: how can I access parent component attribute if the name of attribute I got only as a function result?
use current(“attributename” & copy+1)
so for 5 sizes, size1,size2,size3,size4,size5,
for say lenx use…
= current(“size” & copy+1)
returns the value for each copy
Thank you pcmoor!
current function does not allow me to get value of an attribute from parent.
for example =current(“parent!attribute_name”) will return me: “attrribute parent%21attribute_name not found” even if such attribute exist. Maybe you got some solution for that?
place attributes in the child that references the parent,
size1 = parent!size1
Now it’s clear. Thank you very much for your help!
