Hey guys,
I would like to know if its possible to make a televisionscreen play, in the render. (i use v-ray for sketchup)
We have designed a booth, on one of the walls we would to show a playing televisionscreen.
Can someone help me how to make it work?
Like this?
https://cdnb.artstation.com/p/assets/images/images/013/574/961/original/liam-keating-liam-keating-tv3.gif?1540233414
You can use Photoshop to composite the animation into the render. If you have an animated render and want to put an animation inside it then you can do that in After Effects and other compositing software. However if it’s a still Photoshop will do just fine.
I believe @john_drivenupthewall has experimented with embedding animated images directly into the SketchUp model. It’s not officially supported in the UI yet, I think it requires some Ruby scripting.
Yes that’s it, i give it a try thanks a lot
I made a tutorial here: https://www.artstation.com/artwork/e004DZ
In the about section is a link to the PSD file showing how I inserted the movie into into the still render.
@liamk887 thanks, I’ll let you know something, if it worked
I don’t think a $$ XP only extension with no working videos on the site should be in the EW…
john
