Urgent Bug Report: SketchUp 2027: vector PDF export loses foreground faces (GUI and Ruby; 2026 works)
In this small scene, SketchUp 2026 exports correctly, while SketchUp 2027 exports only the purple board, omitting the pyramid and geometric text. The viewport and PNG export remain correct.
The issue occurs with both manual GUI export and Ruby Model#export. It was also reproduced on a second computer.
Environment and sample
  • Windows builds: SketchUp 2026 26.2.243 / SketchUp 2027 27.0.267.
  • Opaque, solid-colored faces and geometric text in copied/nested groups with four active section planes.
  • The purple board is a real model face. No textures or transparency are involved.
  • PDF pages are approximately 340 × 211 mm. No proprietary model or business extension is required.
Steps to reproduce
  1. Start SketchUp 2027 with a new, empty model. Remove the default person and any existing geometry.
  2. Run the attached export_pdf_ruby.rb in the Ruby Console or Ruby Code Editor. It creates the sample scene and automatically exports one PDF.
  3. After the script finishes, also try exporting manually through File > Export > 2D Graphic > PDF, using full scale (1:1).
  4. Open the exported PDFs: both contain only the purple board, although the foreground remains visible in SketchUp and in the exported PNG.
  5. Run the same script in an empty SketchUp 2026 model for comparison: the exported PDF includes the text and pyramid correctly.
The reproduction script was generated using GPT-6.1 Sol (Extra High reasoning). The export behavior described here was tested in SketchUp.
Expected result
The PDF contains the purple board, white geometric text, and colored pyramid.
Actual result
In SketchUp 2027, the PDF contains only the purple board. The Ruby export call returns true despite the missing foreground.
Impact
This blocks material-colored vector elevation and fill output in our CAD/BIM workflow. PNG cannot replace the required vector faces.
Could the SketchUp team investigate this regression and suggest a workaround that preserves vector face fills?
MyCode
export_pdf_ruby.rb (17.3 KB)
# encoding: UTF-8
# Windows SketchUp 2026 / 2027: run in a NEW EMPTY model (remove default person).
# Ruby Console: load 'D:/your/path/export_pdf_ruby.rb'
# Ruby Code Editor: execute this entire file. Stop: ExportPdfRuby.stop!
# One native vector PDF, then PNG / SKP / TXT / JSON under Desktop/TS_Debug.
# No business plugin, API interception, PDF rewriting or automatic retries.
# A successful API return or a small PDF does NOT determine reproduction/root cause.
require 'json'
require 'time'
require 'fileutils'
unless defined?(ExportPdfRuby::VERSION)
  module ExportPdfRuby
    VERSION = '1.0.0'
    OWNER = 'export_pdf_ruby'
    MM = 1.0 / 25.4 # Native SU coordinates are inches, regardless of template units.
    RENDER = {'RenderMode'=>2, 'EdgeDisplayMode'=>0, 'EdgeColorMode'=>0,
              'DrawSilhouettes'=>false, 'DisplayColorByLayer'=>false, 'DrawHidden'=>false,
              'DisplaySectionCuts'=>true, 'DisplaySectionPlanes'=>false,
              'SectionCutDrawEdges'=>true, 'SectionCutFilled'=>true}.freeze
    SHADOW = {'UseSunForAllShading'=>true, 'Light'=>0, 'Dark'=>80, 'DisplayShadows'=>false}.freeze
    class << self
      attr_reader :current
      def clock; Process.clock_gettime(Process::CLOCK_MONOTONIC); end
      def desktop
        return File.join(Dir.home, 'Desktop') unless Sketchup.platform == :platform_win
        require 'win32ole'
        path = WIN32OLE.new('WScript.Shell').SpecialFolders('Desktop').to_s
        raise '系统桌面路径为空' if path.empty?
        path
      end
      def run
        if @current && !@current.done?
          puts '[export_pdf_ruby] 本轮仍在运行,不重复启动;可用 ExportPdfRuby.stop! 停止。'
          return @current
        end
        raise '请在 SketchUp Ruby 控制台或 Ruby Code Editor 中执行' unless defined?(Sketchup::Model)
        model = Sketchup.active_model
        raise '请退出组/组件编辑,再新建空白模型运行' if model.active_path
        raise '请新建空白模型并移除默认人物;脚本不会清空已有几何' unless model.entities.length.zero?
        @current = Session.new(model)
        @current.start
        @current
      rescue StandardError, LoadError => e
        @current.stop!("setup_failed: #{e.message}") if @current && !@current.done?
        message = "[export_pdf_ruby] 未启动:#{e.class}: #{e.message}"
        puts message
        UI.messagebox(message) if defined?(UI)
        nil
      end
      def stop!; @current.stop! if @current && !@current.done?; end
    end
    class Session
      attr_reader :directory, :data, :scene
      def initialize(model)
        @model=model; @view=model.active_view; @started=Time.now; @started_clock=ExportPdfRuby.clock
        @scene={}; @timers=[]; @done=false; @stopped=false; @busy=false; @attempted=false; @phase='starting'
        year=Sketchup.version.to_i; @year=year<2000 ? year+2000 : year
        @stamp=@started.strftime('%Y%m%d_%H%M%S_')+format('%03d', @started.usec/1000)
        @data={'owner'=>OWNER, 'script_version'=>VERSION, 'status'=>'running', 'errors'=>[], 'events'=>[],
          'stage_ms'=>{}, 'native_export_called'=>false, 'reproduction_status'=>'not_assessed', 'root_cause'=>'not_determined',
          'environment'=>{'sketchup_version'=>Sketchup.version, 'sketchup_version_number'=>Sketchup.version_number,
            'ruby_version'=>RUBY_VERSION, 'ruby_description'=>RUBY_DESCRIPTION, 'ruby_platform'=>RUBY_PLATFORM,
            'sketchup_platform'=>Sketchup.platform.to_s, 'pid'=>Process.pid, 'time'=>@started.iso8601(3),
            'utc_offset_seconds'=>@started.utc_offset},
          'scene_parameters'=>{'units'=>'mm', 'board_width'=>300, 'board_height'=>200,
            'frame_min'=>[-140,-70,10], 'frame_max'=>[140,70,190], 'board_offset'=>10, 'cut_overlap'=>2,
            'label'=>"SKETCHUP\n#{@year}", 'font'=>'Arial Bold', 'letter_height'=>16,
            'pdf_scale'=>'1:1; actual PDF MediaBox must be checked separately'}}
        failures=[]
        [proc { File.join(ExportPdfRuby.desktop, 'TS_Debug') }, proc { File.join(Sketchup.temp_dir, 'TS_Debug') }].each_with_index do |candidate,i|
          begin
            root=candidate.call; FileUtils.mkdir_p(root)
            base="#{OWNER}_#{@stamp}_su#{@year}_pid#{Process.pid}"
            100.times do |n|
              path=File.join(root, base+(n.zero? ? '' : "_#{n}"))
              begin; Dir.mkdir(path); @directory=path; break; rescue Errno::EEXIST; end
            end
            raise '无法分配新的取证目录' unless @directory
            @data['environment']['output_fallback_to_temp']=i==1
            @data['environment']['output_directory']=@directory
            checkpoint
            break
            failures << "#{e.class}: #{e.message}"; @directory=nil
          end
        end
        raise "桌面与临时取证目录均不可写:#{failures.join(' | ')}" unless @directory
        @data['environment']['output_directory_warnings']=failures unless failures.empty?
      end
      def done?; @done; end
      def event(name, extra={})
        @data['events'] << {'stage'=>name, 'time'=>Time.now.iso8601(3),
          'elapsed_ms'=>((ExportPdfRuby.clock-@started_clock)*1000).round(3)}.merge(extra)
      end
      def error(stage, exception)
        @data['errors'] << {'stage'=>stage, 'class'=>exception.class.to_s,
          'message'=>exception.message, 'backtrace'=>Array(exception.backtrace).first(5)}
      end
      def attempt(stage)
        began=ExportPdfRuby.clock
        yield
      rescue StandardError, NotImplementedError => e
        error(stage,e); nil
      ensure
        @data['stage_ms'][stage]=((ExportPdfRuby.clock-began)*1000).round(3)
      end
      def checkpoint
        json=JSON.pretty_generate(@data)
        File.write(File.join(@directory, 'evidence.json'), json+"\n", mode:'w:UTF-8')
        File.write(File.join(@directory, "collect_evidence_#{@stamp}.txt"),
          "Owner=#{OWNER}\n#{@started.iso8601(3)}\nPDF content / root cause: not assessed / not determined.\n\n#{json}\n", mode:'w:UTF-8')
      end
      def later(seconds, &block)
        id=nil
        id=UI.start_timer(seconds, false) do
          @timers.delete(id)
          begin; block.call if live?; rescue StandardError, NotImplementedError => e; error(@phase,e); finish; end
        end
        @timers << id
      end
      def live?
        return false if @done || @stopped
        unless Sketchup.active_model.equal?(@model) && !@model.active_path
          stop!('active_model_or_edit_context_changed'); return false
        end
        true
      end
      def start
        puts "[export_pdf_ruby] SU #{Sketchup.version},PID #{Process.pid};本轮只导出一次 PDF。\n[export_pdf_ruby] #{@directory}"
        later(30.0) { stop!('view_callback_timeout') unless @attempted }
        later(0.0) { build }
      end
      def group(entities,name)
        g=entities.add_group; g.name=name; g
      end
      def material(name,rgb)
        m=@model.materials.add("#{OWNER}_#{name}"); m.color=Sketchup::Color.new(*rgb); m.alpha=1.0; m.texture=nil; m
      end
      def paint(face,mat)
        raise '素材面创建失败' unless face
        face.material=mat; face.back_material=mat; face.edges.each { |e| e.hidden=true }; face
      end
      def build
        return unless live?
        @phase='building'; began=ExportPdfRuby.clock
        @model.start_operation('Small native PDF reproduction',true); @operation=true
        source=group(@model.entities,'source_geometry'); @scene['source']=source
        white=material('white',[255,255,255]); purple=material('purple',[170,85,255])
        # Filled zero-extrusion text becomes ordinary faces, not a screen overlay.
        ok=source.entities.add_3d_text("SKETCHUP\n#{@year}",TextAlignLeft,'Arial',true,false,16*MM,0.0,0.0,true,0.0)
        raise '版本文字生成失败(Arial)' unless ok && !source.entities.grep(Sketchup::Face).empty?
        box=source.bounds
        transform=Geom::Transformation.axes([-75*MM-box.center.x,-45*MM,100*MM-box.center.y],[1,0,0],[0,0,1],[0,-1,0])
        source.entities.transform_entities(transform,source.entities.to_a)
        source.entities.grep(Sketchup::Face).each { |f| paint(f,white) }
        @data['text_face_count']=source.entities.grep(Sketchup::Face).size
        # Diamond base: front view sees two differently colored triangular faces.
        vertices=[[10,0,30],[70,-60,30],[130,0,30],[70,60,30],[70,0,160]].map { |p| p.map { |n| n*MM } }
        colors=[[0,210,210],[255,220,30],[255,145,30],[100,210,80],[80,160,255]]
        [[0,3,2,1],[0,1,4],[1,2,4],[2,3,4],[3,0,4]].each_with_index do |indices,i|
          paint(source.entities.add_face(indices.map { |n| vertices[n] }),material("pyramid_#{i}",colors[i]))
        end
        @data['pyramid_vertices_mm']=vertices.map { |p| p.map { |n| (n/MM).round(6) } }
        [['current_background',-80],['opposite_background',80]].each do |name,y|
          board=group(@model.entities,name)
          paint(board.entities.add_face([[-150,y,0],[150,y,0],[150,y,200],[-150,y,200]].map { |p| p.map { |n| n*MM } }),purple)
          board.visible=name=='opposite_background'; @scene[name]=board
        end
        # Original copy + four nested active sections; recompute each local plane
        # because native add_group may choose a local origin. All lengths are small.
        move=Geom::Transformation.new([0,0,100*MM])
        copy=source.copy; copy.visible=true; copy.material=white; copy.transform!(move.inverse)
        @scene['visible_copy']=copy
        g=copy
        %w[top bottom left right].each_with_index do |side,i|
          g=@model.entities.add_group(g); g.name="cut_#{side}"; g.material=white
          o=Geom::Point3d.new(0,0,0).transform(g.transformation.inverse)
          planes=[[0,0,-1,o.z+92*MM],[0,0,1,92*MM-o.z],[1,0,0,142*MM-o.x],[-1,0,0,142*MM+o.x]]
          s=g.entities.add_section_plane([1,1,1],[1,1,1]); s.set_plane(planes[i]); s.hidden=true; s.activate
        end
        g.transform!(move); @scene['cut_group']=g; source.visible=false
        RENDER.each { |k,v| @model.rendering_options[k]=v }; SHADOW.each { |k,v| @model.shadow_info[k]=v }
        @model.selection.clear
        camera=@view.camera; camera.perspective=false; camera.aspect_ratio=0.0
        camera.set([500*MM,0,100*MM],[0,0,100*MM],[0,0,1]); camera.height=240*MM; @view.camera=camera
        @model.commit_operation; @operation=false
        @data['stage_ms']['build']=((ExportPdfRuby.clock-began)*1000).round(3)
        event('scene_created'); request('viewRight:','right')
        attempt('abort_build') { @model.abort_operation } if @operation
        @operation=false; error('build',e); finish
      end
      class Observer < Sketchup::ViewObserver
        def initialize(session,role); @session=session; @role=role; @count=0; end
        def onViewChanged(view); @count+=1; @session.changed(self,view,@count,@role); end
      end
      def request(action,role)
        return unless live?
        @phase="waiting_#{role}"; @observer=Observer.new(self,role)
        raise '无法添加视图观察器' if @view.add_observer(@observer)==false
        event('view_request',{'action'=>action})
        raise "视图请求失败:#{action}" if Sketchup.send_action(action)==false
      end
      def detach
        @view.remove_observer(@observer) if @observer
        @observer=nil
      end
      def changed(observer,view,count,role)
        return unless live? && @observer.equal?(observer) && view.equal?(@view)
        event('view_callback',{'role'=>role,'index'=>count})
        if count==1
          # Preserve original nil @cur_gri guard semantics: only opposite board.
          @model.selection.add(@scene['opposite_background'])
          event('zoom_selection',{'names'=>@model.selection.map(&:name)})
          raise '缩放请求失败' if Sketchup.send_action('viewZoomToSelection:')==false
          @view.refresh if live?
        elsif count==2
          detach; @model.selection.clear; @scene['current_background'].visible=false
          view.invalidate; view.refresh
          role=='right' ? later(0.01) { request('viewFront:','front') } : export_pdf
        end
        error('view_callback',e); finish
      end
      def entity_info(g)
        b=g.bounds; f=g.entities.grep(Sketchup::Face).first
        {'name'=>g.name, 'persistent_id'=>g.persistent_id, 'visible'=>g.visible?, 'hidden'=>g.hidden?,
          'bounds_in'=>[b.min.to_a,b.max.to_a], 'transformation'=>g.transformation.to_a,
          'color'=>f && f.material && [f.material.color.red,f.material.color.green,f.material.color.blue]}
      end
      def snapshot
        c=@view.camera; w=@view.vpwidth.to_f; h=@view.vpheight.to_f
        raise '视口宽高无效' unless w>0 && h>0
        chain=[]; g=@scene['cut_group']
        while g && (s=g.entities.active_section_plane)
          chain << {'group'=>g.name, 'transform'=>g.transformation.to_a,
            'plane'=>s.get_plane, 'active'=>s.active?, 'hidden'=>s.hidden?}
          g=g.entities.grep(Sketchup::Group).first
        end
        {'camera'=>{'eye'=>c.eye.to_a,'target'=>c.target.to_a,'up'=>c.up.to_a,'direction'=>c.direction.to_a,
            'perspective'=>c.perspective?,'height_mm'=>c.height.to_f/MM,'aspect_ratio'=>c.aspect_ratio,
            'estimated_view_width_mm'=>c.height.to_f/MM*w/h},
          'viewport'=>{'width'=>w,'height'=>h}, 'model_guid'=>@model.guid,
          'rendering'=>RENDER.keys.to_h { |k| [k,@model.rendering_options[k]] },
          'shadow'=>SHADOW.keys.to_h { |k| [k,@model.shadow_info[k]] },
          'selection'=>@model.selection.map(&:name),'section_chain'=>chain,
          'source'=>entity_info(@scene['source']), 'visible_copy'=>entity_info(@scene['visible_copy']),
          'cut_group'=>entity_info(@scene['cut_group']),
          'current_background'=>entity_info(@scene['current_background']),
          'opposite_background'=>entity_info(@scene['opposite_background'])}
      end
      def file_info(path)
        {'path'=>path,'exists'=>File.file?(path),'bytes'=>File.file?(path) ? File.size(path) : nil}
      end
      def export_pdf
        entered=false
        return unless live? && !@attempted
        @attempted=true; @busy=true; entered=true; @phase='exporting'
        options={show_summary:false, output_profile_lines:false, output_section_lines:false, map_fonts:false,
          drawing_units:Length::Millimeter, extension_units:Length::Millimeter, height_units:Length::Millimeter,
          width_units:Length::Millimeter, model_units:Length::Millimeter,
          full_scale:true, length_in_drawing:1.0, length_in_model:1.0}
        @data['pdf_options']=options.dup
        @data['before_pdf']=attempt('snapshot') { snapshot }
        return unless live? # State reads may pump UI; recheck at the actual native boundary.
        path=File.join(@directory,"export_pdf_su#{@year}.pdf")
        event('pdf_export_before'); @data['native_export_called']=true
        result=attempt('native_pdf') { @model.export(path,options) }
        @data['pdf']=file_info(path).merge('return_value'=>result)
        error('native_pdf_result',RuntimeError.new('PDF export returned false/nil or file is missing')) unless result && File.file?(path)
        event('pdf_export_after'); checkpoint
        if live?
          attempt('png') do
            ratio=[1.0,1280.0/[w,h,1].max].min
            if live?
              png=File.join(@directory,'after_export.png')
              ok=@view.write_image(filename:png,width:[1,(w*ratio).round].max,height:[1,(h*ratio).round].max,antialias:false)
              @data['png']=file_info(png).merge('return_value'=>ok,'timing'=>'after_native_pdf')
              raise 'PNG export failed or file is missing' unless ok && File.file?(png)
            end
          end
        end
        if live?
          attempt('model_copy') do
            skp=File.join(@directory,'after_export.skp'); ok=@model.save_copy(skp)
            @data['model_copy']=file_info(skp).merge('return_value'=>ok,'timing'=>'after_native_pdf')
            raise 'SKP copy failed or file is missing' unless ok && File.file?(skp)
          end
        end
        error('export',e)
      ensure
        if entered
          @busy=false
          finish
        end
      end
      def stop!(reason='manual_stop')
        return if @done || @stopped
        @stopped=true; error(@phase,RuntimeError.new(reason))
        cleanup; finish unless @busy
      end
      def cleanup
        attempt('detach_observer') { detach }
        @timers.each { |id| attempt('stop_timer') { UI.stop_timer(id) } }; @timers.clear
      end
      def finish
        return if @done
        @done=true; cleanup
        @data['status']=@data['errors'].empty? ? 'completed' : 'partial'
        @data['finished_at']=Time.now.iso8601(3); @data['elapsed_ms']=((ExportPdfRuby.clock-@started_clock)*1000).round(3)
        checkpoint
        puts "[export_pdf_ruby] 实验结束:#{@data['status']};PDF 内容是否漏导需核对,根因尚未确定。\n[export_pdf_ruby] #{@directory}"
      rescue StandardError => e
        @data['status']='partial'
        puts "[export_pdf_ruby] 取证日志保存失败:#{e.class}: #{e.message}\n[export_pdf_ruby] #{@directory}"
      end
    end
  end
end
ExportPdfRuby.run
Usage export_pdf_ruby.rb (17.3 KB)
  1. Start SketchUp and open a new, empty model. Remove the default person and any existing geometry.
  2. Open SketchUp’s Ruby Console.
  3. Paste the following command into the console and press Enter:
path = UI.openpanel('Select export_pdf_ruby.rb', nil, '*.rb'); load(path) if path
  1. In the file selection dialog, locate export_pdf_ruby.rb, select it, and click Open.
  2. The script automatically creates the sample scene and exports a PDF, followed by a PNG, a model copy, and diagnostic logs. Keep the model active and avoid changing the view until the completion message appears.
Results are saved under Desktop/TS_Debug, in a separate folder for each run. The Ruby Console prints the actual output path, including any fallback to the temporary directory.
For comparison, repeat these steps in SketchUp 2026 and 2027 using the same script. Use a fresh empty model for each run.
The native PDF exporter works fine. Expecting the SketchUp developers to urgently fix your script seems like a long shot to me. They have their own work to do. There are changes to Ruby from SketchUp 2026 to 2027.
I too exported fine using the native exporter. Is your ruby script doing something “illegal”, for instance, modifying the way the native exporfter works?
Thanks for checking. I tested three PDF output routes in SketchUp 2027:
  • Ruby Model#export: the PDF contains only the purple board; the foreground geometry is missing.
  • File > Export > 2D Graphic > PDF: the same failure occurs when exporting manually after the script has finished.
  • Ctrl+P → Microsoft Print to PDF: works correctly and preserves the foreground geometry.
The script does not override or monkey-patch Model#export or any native API. It creates the scene and sets its view/rendering state using native APIs.
The issue concerns 2D Graphic PDF export for this scene, while printing to PDF works. Could you please confirm which output route you tested?
I made a similar model to yours and used the native exporter. I am not going to run untested ruby scripts that might be modifying SU core functionality.
Just an idea: Is your script setting the camera so that it is located between the pyramid and the “wall”? In that case what you see in the export would be plain old camera clipping. Some people make use of the “feature” for creating interior elevation views without using section planes.
@colin
Hi Colin, I’ve submitted a detailed regression report about vector PDF export in SketchUp 2027 losing foreground faces (works correctly in 2026). Both the GUI export and Ruby Model#export are affected. I’ve included a minimal reproduction script and side-by-side comparison. Would you mind taking a look when you have a chance? Thank you.
I see the problem in 2027.0 and 2027.0.2 (the update that came out a couple of days ago). If I try my latest internal version I don’t see the problem.
I couldn’t find a bug report where a recent fix would account for it no longer going wrong. @TedVitale_SU may know of a fix for the issue.
The fix should be in the next update we release. I can’t yet tell you a date for when that will happen.
