Installed the pro 2019
Based on mail the 7th of February where my humble person was entitled to a FREE license upgrade. Just follow the steps outlined below to access the brand new features of SketchUp Pro 2019.
Authenticated with classic (perpetual license information).
And then all the fun suddenly was removed, can’t do anything with the ■■■■ software.
When starting the software, the work space doesn’t show up.
Removing, re-installing, re-booting, nothing seems to work, new version of sketchup not compatible with surface pro machine ?
Version sketchup pro 2018 still works on the same machine.
Can select a file and it is indicated open, nothing shows, attached screenshot same with or without loaded file.
While opening the file the usual warning, for constraints of saving to new version of sketchup.
If the page is printed to pdf, then this looks ok attached output test.pdf
However in current form and shape the pro 2019 is useless.
Running windows pro 1809 os build 177163.316 on surface pro
Has anyone else encountered similar, if so how was this problem solved ?
Stefan
