Here is a view of the underside of the same area, I checked to see if maybe I had a couple of stray lines, but as you can see there is none. What causes this?
It would seem all you want is a simple solid color material.
But the unwanted streak appears to be the result of using a Texture Image
Click … Window > Materials > In Model (little house icon)
There, select the material in question and then click on the Edit tab
There, deselectUse Texture Image
Then click… Window > Model Info > Statistics > Purge Unused
Try this…
Switch All Layers ON
AND
Also View > Hidden Geometry > ON
I think your issue is that you have some unexpected subdivision of the surface by off/hidden geometry…
Also ensure nothing is unexpectedly sub-grouped…
Apply the material to faces, not groups or component-instances…
Always put ‘raw’ geometry on Layer0.
But why not post your SKP with the issue so we can be sure…
