Uninstall SketchUp Pro 2023
Hello Friends, can you please send me SketchUp 2023 exe installation file? I have managed to uninstall SketchUp Pro 2021 by following an older post and creating a shortcut SketchupPro-2021-1-332-116.exe - remove -silent. This method worked very well for 2021 version, now I need to do the same with 2023 version.
2021 had a particular problem, where you couldn’t uninstall it if later versions were also installed. 2023 shouldn’t have that problem. The normal Windows Add or Remove Programs control panel should run the installer ok, and successfully remove 2023.
Thanks Colin.
