"Unexpected file format"
As with other cases I recovered the materials, tags, and components, but the scene is empty:
https://we.tl/t-46C1JwciMq
Alright, Thank u very much
Anyway did u know why is happened to the files? Its corrupted, failed when saving, or its just a bad luck
Not sure in your case but the most common reason this happens is due to saving SketchUp files to external drives or the cloud. A very brief interruption in the connection during a save or autosave can result in the file becoming corrupted.
i always work on local disk, its just happend
when i finished my modelling then save and close it, and start to import to lumion and then lumion can’t import my skp file. so i check my skp file, and the skp file can’t open
its so frustating
Did you do those two things very quickly, perhaps Sketchup hadn’t finished saving when Lumion tried to import it.
i dont think so,i did everything normally
perhaps its just random system failure
Please help @colin
I’m having a very similar situation with the file, i’ve tried everything on the internet but nothing worked, here’s my file Important Model Skp 2019.skp - Google Drive
Hi there, i have same problem and i think my problem was :
1-check if you have enough disk space on that drive
2-check for file name and directory name, not being too long or special characters
3- dynamic components in your model too
these were my toughts and my file got ok!!!
