Unable to setup VS Code debugger for SketchUp Ruby
Here is the instruction for correctly posting code …
John he’s actually posting JSON configuration files from MS VSCode. They’re the same format SketchUp now uses for preference files.
So it’d be …
```json
// code here
Ie my "launch.json" file …
    // Use IntelliSense to learn about possible attributes.
    // Hover to view descriptions of existing attributes.
    // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
    "version": "0.2.0",
    "configurations": [
        "name": "Listen for SURubyDebugger.DLL",
        "type": "Ruby",
        "request": "attach",
        "cwd": "${workspaceRoot}",
        "remoteHost": "127.0.0.1",
        "remotePort": "7000",
        "remoteWorkspaceRoot": "${workspaceRoot}"
And my "tasks.json" file …
    // See https://go.microsoft.com/fwlink/?LinkId=733558
    // for the documentation about the tasks.json format
    "version": "2.0.0",
    "tasks": [
        "label": "Debug SketchUp 2016",
        "type": "shell",
        "command": "open -a '/Applications/SketchUp 2016/SketchUp.app' --args -rdebug 'ide port=7000'",
        "windows": {
          "command": "&'C:/Program Files/SketchUp/SketchUp 2016/SketchUp.exe' -rdebug 'ide port=7000'"
        "label": "Debug SketchUp 2017",
        "type": "shell",
        "command": "open -a '/Applications/SketchUp 2017/SketchUp.app' --args -rdebug 'ide port=7000'",
        "windows": {
          "command": "&'C:/Program Files/SketchUp/SketchUp 2017/SketchUp.exe' -rdebug 'ide port=7000'"
        "label": "Debug SketchUp 2018",
        "type": "shell",
        "command": "open -a '/Applications/SketchUp 2018/SketchUp.app' --args -rdebug 'ide port=7000'",
        "windows": {
          "command": "&'C:/Program Files/SketchUp/SketchUp 2018/SketchUp.exe' -rdebug 'ide port=7000'"
        "label": "Debug SketchUp 2019",
        "type": "shell",
        "command": "open -a '/Applications/SketchUp 2019/SketchUp.app' --args -rdebug 'ide port=7000'",
        "windows": {
          "command": "&'C:/Program Files/SketchUp/SketchUp 2019/SketchUp.exe' -rdebug 'ide port=7000'"
When I run a task SketchUp starts and in the terminal pane I see …
> Executing task: &'C:/Program Files/SketchUp/SketchUp 2018/SketchUp.exe' -rdebug 'ide port=7000' <
Terminal will be reused by tasks, press any key to close it.
No error. I’ve got VSCode version 1.27.2.
I see an update for VSCode is available. I’ll update and see if I still have no error.
