I can’t open my file (last modified yesterday) it says ‘unable to open’ I have tried to open the skb file (renaming it) but it doesn’t work. Any help? It is too big to upload here
Share the files via a file sharing service like DropBox. Post the link here.
right!
here is my google drive link:
thank you!
Is that where you’ve been saving the file while you’ve been working on it? If so, don’t. That’s a good way to wind up with fatally corrupted files. Fortunately in this case your file isn’t corrupted. Your file opened fine for me. It looked like this on open.
Try downloading it to your computer from the link in your post and see if it will open.
I went through my standard cleaning process. Untagged should be active at all time. Don’t make tags active as you have here.
I fixed incorrect tag usage. ALL edges and faces should be created and remain untagged.
I purged unused content. This is something you should do on a regular basis.
There are a few excessively large textures which I reduced with Material Resizer.
I also ran CleanUp3 which merged a lot of coplanar faces and reduced the number of edges. Another thing it did is consolidate a bunch of identical textures.
The cleaning I did reduced the file size by nearly 40%. There seems to be a yard sale outside of the building. Do you need those objects? If not getting rid of them, including purging unused content will firther reduce the file size and complexity and make it easier for your computer to handle it.
thank you so much, unfortunately I can’t open it (even from the link that worked for you) … thank you for all the suggestions and correction. Could you share the file you opened and purged? May be I can open that one…thank you!
Here’s the link. I did delete and purge the furniture that was scattered outside the building, though.
thank you!
