hello,
I’m trying to create a window, but i can’t extrude on the yellow walls. On the green walls there is no problem.
Can you help me ?
plan aide.skp (796.3 KB)
hello,
Can you help me ?
Do you want your yellow wall to be wider at the base (~24 cm) and narrower at the top (20 cm)?
If you do, select the face and use Move instead of Push/Pull.
This topic was automatically closed after 186 days. New replies are no longer allowed.
