hi thank you for the help. but I seem to be completely at a loss.
I have all my drawings entered on a new computer, there is absolutely nothing on this computer other than the software that came with it.
I then down loaded sketch up 2017 as some of the drawings are in sketch up 2017 and some are in sketch up 2018, so I was going to start with the 2017 ones and once I was able to correct them I was going to save them and then later move them so they are all compatible with 2019.
so the only thing that is on my computer are the drawings that are in documents, they are not in a folder, all drawings are in documents I say this so you can understand that nothing else is on this computer, nothing. no games, no apps, no nothing.
I open up sketch up 2017 and then go to file and then press the open key. when I do that 17 drawings show up. if I pick any of them they open, spin, can be changed , I can erase numbers, spin the drawing 360 degrees, erase it etc, just the exact same as it would if I were drawing it. So that is exactly what I would expect should happen when I open a drawing.
so now I go to file, press open at the bottom left corner where it says sketch up models (* .skp) I change that to all files and the drawing names show up in the documents. so I pick the first one and try to open it ( or any file) and a box comes up which says that this does not appear to be a sketch up model.
I have tried using the back up folder for these drawings and it says the same thing.
I have taken a drawing, removed the text, saved it and tried to open that file but it also says that it does not appear to be a model.
so I can not open any drawing to edit it.
I can, as you said, add arrows to these drawings, I can add text, or erase the text, but I can not in any way open them or edit them
if I use sketch up viewer I get the exact same 17 drawings that I can do anything I want with but just like sketch up. If I try to open any other drawing it says it appears not to be a model
when I open layout the 17 drawings are not available, just all the drawings in documents. if I pick a drawing that was made with 2018 the message comes up that this is file was made with a newer version of layout (2018) and is not compatible with this version. this version of layout is 2017. use a version 2018 or higher to open this file,
when I open the drawings that were made with the 2017 version they open and can not be edited. I can add a label, I can add text, I can remove text, but I can not do anything to the model, it basically is simply a picture and not a drawing (model)
so how do I open these drawings to be models like the 17 of them are that are in the stored files ( I am guessing) on sketch up. in the past on the old computer they opened just fine and were able to be edited without a problem.
so I have no clue what is going wrong or what buttons I am not hitting
there is nothing on this computer that would have corrupted the files. the older computer was also only used for drawing these models and was why it was chosen to be used as it had no other function or purpose than to do the drawings, it was not used for anything else. even the files that were backed up onto memory sticks were checked to see that they transferred properly and were able to be opened. however these exact same back up files have the same problem and can not be opened,
I have taken another computer, down loaded 2019, imported a drawing ( as sketch up redoes it to be compatible with the 2019 version) and again the drawings do not allow for any modeling. they are basically pictures and not models.
so what am I missing as I have no idea why these drawings do not just load and open as they did before and I have no idea which buttons I need to push to open them.
I have tried opening them in all 3 possible scenarios. and have followed your instructions but simply can not open the drawings (models), they are just pictures with all the paint stuck together.
i have tried all that you have said but i am not able to do anything with the drawings
i am sorry as i have no clue what is wrong.
allan
