I was given some designs for our new pool area and decide to recreate it in sketchup make to play around with different colours and materials. Now when I try to add texture like tiles, it just adds a solid colour. I tried to search the forum for answers and have tried reversing faces and no luck. I wondered if it was a memory issue, but when I created a new picture it worked just fine. I suspect I have tweaked a setting somehow, but I have no idea what. Any ideas?
View in Monochrome mode.
All faces should be off-white, any that are blue-gray are reversed.
Reverse them by selecting and using the context menu item.
Also if the pond [?] is grouped or a component you need to edit it to add materials onto faces [and reverse mis-oriented faces too.
If you add the material to the group/component it will only show on front faces…
Thanks Tig. I will keep trying. I keep trying to reverse faces and can’t seem to get it white. The pool is a group so I did try going into it with not much luck. I will try again when the kids go to bed. In frustration i started again but the other one is still a mystery. It didn’t help that when i started my first one it had been a while since using SU so was a bit of trial and error.
