Turn 2d floor plan to 3d
Is there a question in this??
If you come here for help on a problem, you’ve got to give as much information on the problem as you can..
Don’t make us guess!!
Those are schematic drawings, you should at least draw the floor plan of the final design, this is not chat gpt. You probably tried using ai and come here as last resource finding someone to do your job. Also steam is an operative system based on Linux and it’s for gaming. Sketchup doesn’t run on Linux natively, and according to some Linux users there’s no way to run sketchup on Linux. You need to install windows or get a Mac to run sketchup natively. My recommendation is if you need a portable device, the Mac is the best option, but if you want an stationary device, go with a tower PC, it’s more bang for the buck, even though macstudios are quite powerful as well.
“Floor plan” is a term normally reserved for something that can and should be built. Start with that.
It appears you are expecting some sort of automatic SketchUp model generation. This is a user forum. It is not an AI service that will take your prompts to create a 3D model for you. Or maybe you want to hire another SketchUp user to create a 3D model based on your schematic? If that’s what you want you’ll need to provide a lot more information.
This is a joke posting, right? Perhaps “steam” under OS means as in steam engine. As for “100” under graphics card, that is surely meaningless.
You seem to have started with the kind of floor plan that an amateur might produce, given that it has no wall thicknesses and no windows or doors. You could not turn that into a 3D model without a lot more work on the 2D plan.
You seem to have asked for Sketchup/advice. So let’s assume you do actually have some version of Sketchup available to you and the hardware to run it (not a given, I’d say, but let’s run it up the flagpole). The main advice would have to be: learn how to use Sketchup! There are many good tutorials.
There actually still is no question at all..
I agree with @DaveR. This seems like someone (or something) poking the forum to see if it behaves like an AI chatbot. The title can be read as a prompt, and the diagram as a schematic from which the AI is supposed to creatively hallucinate all the missing information.
I wonder where people get the idea that a forum is a place for this kind of thing.
discord. on AI-powered discords, you post, it answers.
Hmmm …
Payment agreed in weed.
if true:
return money
else:
42
I didn’t know that, good to know..
It explains why people come here expecting an instant 3D model without even asking a question..
The OP has spent less than a minute on the forum and certainly none of that was in the last 4 days, so I’d suggest we let it drop. Do’h I have just bumped it again.
Thesw are the first things I look at:
  • when joined the forum
  • how much time spent here to find answers themselfs
  • how much information is given to get us started to guess
  • how is the question (if at all) formulated
  • what does the OP’s forum name look like.
In the “end” the balance outcome makes me decide to invest in an answer,
And like here, if OP doesn’t read his own thread, it’s not worth it to join.
Yeez, I just did.
Concider this thread closed (until OP returns)
