Hi to you all and Thom
After I install QuadFace Tools, I run into a problem.
I got this Error
How can I fix it?
Thanks
I got this Error
Thanks, Mihai for the quick reply
In the Extension Warehouse, there is Version 2.12.1
Where can I find Version 2.7.0?
2.12 it’s newer, it’s actually the latest and you can install it.
Don’t forget to restart SketchUp after installing the extension.
Thanks, Mihai I appreciate all your help. I Install It again and restart SketchUp and unfortunately, it still sends this Error.
Error: #<NameError: uninitialized constant Infinity>
:in `' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_Lib2/settings.rb:51:in `eval' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_Lib2/settings.rb:51:in `read_default' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_Lib2/settings.rb:51:in `[]' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_Lib2/settings.rb:96:in `set_default' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_QuadFaceTools/core.rb:63:in `' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_QuadFaceTools/core.rb:35:in `' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in `require' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:72:in `require' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_QuadFaceTools/bootstrap.rb:35:in `' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `require' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in `load' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_QuadFaceTools.rb:54:in `register_extension' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_QuadFaceTools.rb:54:in `' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_QuadFaceTools.rb:15:in `' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_QuadFaceTools.rb:14:in `' C:/Users/oshri/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/TT_QuadFaceTools.rb:13:in `'Thanks,
I put the code
TT::Plugins::QuadFaceTools.settings[ :uv_u_scale ] = 1.0
TT::Plugins::QuadFaceTools.settings[ :uv_v_scale ] = 1.0
inside of the Ruby Console
and it works
Thanks again
I found that there’s a bug in Sketchup.read_default that prevents the error from being catched. Hence my recovery logic not working. Working on another workaround.
Published 0.14.1 that should be able to better recover and prevent the issue. If you already issue you will probably get the error again the first time you load after updating, but should repair itself after that.
Thank you for your help.
