I am trying to draw a line around the room to be able to use the follow me tool. However part of my line is black and the other part stays grey no matter what I do. The follow me tool does not want to pull the shape on to the grey section of my line. What am I doing wrong?
The object I am trying to use follow me on is a group. But I also get this error message. It worked the whole way around the room and now it’s just not going over the line here. I don’t know what the difference is.
I started over by copying the profile out. Do that by double clicking with Select on the end of the molding. This is done with the group opened into edit mode. Then hit Ctrl+C to copy it. Click outside the group to close it and then delete it. After it’s gone, hit Edit>Paste in place.
I left the molding above the walls so it won’t join with the walls. See the little white thing near the cursor. Then select the top edges of the walls. Hold Ctrl or Shift while selecting them. Make sure you select all of the edges around the room.
With Select, triple click on the molding and then right click on it and choose Reverse faces so the white front faces are facing out. Then, while it is all selected, right click on it and choose Create Group (or Create Component). Finally, move the molding down into the room.
While you are doing this stuff, triple click on the walls with Select, the right click and choose Reverse Faces. Then make a group or component of the walls so that stuff you add later doesn’t stick to them
