Trouble building a couple of angled intersecting walls
I am stumped! I am trying to draw a couple of angled walls that intersect at a 45 degree angle. I am able to draw the vertical surfaces, but am unable to close the tops no matter what I do! Can anyone help with what I’m doing wrong?
Draw diagonals using Line tool, then soft and smooth them.
The Z dimension of the verticals at the intersection will all be different as the slope length at the top of the walls vary from the top edges. This is why you need the diagonals to close the faces.
Imagine if the return walls were at 90 degrees. What would you expect to see at the top of the walls?
Worked like a charm! Thanks so much for your help!
I understand now - thank you!
You’re welcome!
If you want to draw the walls with all their faces right from the start. :wink:
