I use groups in my architectural sketchup models. I build traditional japanese buildings. In order to make the model easier to build and change I make the joinery separate from the main meat of each structural member. complex.group.trim.skp (195.7 KB)
I used groups because the fact that components can change other parts of the model at the same time scares me in regards to the fact that I use the model for layout of each timber and it would be a disaster if other timbers were changed at the same time in the model and I didn’t realize it when laying out the building, and because each part is at times only slightly different it can be hard to see the small change
I wondered if there is a way to trim two groups that have smaller groups (particularly joinery) nested into a larger group which would be the timber used in the structural piece.
and finally, I tend to use Eneroth solid tools trim because it does not delete layer association which the Pro Trim does and irks me because then I constantly have to re-apply a layer after the trim.
thanks for any help!
