Trimble Creator - Boolean mesh
Can anyone help?
I’m creating a cabinet in Trimble Creator. When using the Boolean node, the geometry faces become triangulated, and this is visible in the SketchUp model. I’m adding screenshots (ignore the large parameter list, it’s from other parts of the live component I’m modeling).
Does anyone know how to fix this and have a clean geometry on the SketchUp model?
Hard to say without seeing the actual model.
Possibly with Cleanup3:
Are you able to access the model with this link? I couldn’t find a share button. Sorry, I’m new to this!
I’m guessing you fixed it, it looks fine here
Hi!
Looks like you have an “unweld vertices” node directly after the “3d boolean” node, which will unweld all triangles in the geometry. If you add in a “weld vertices” node after, that should fix up the lines on flat faces!
See: Trimble Creator
Hope that helps!
Thank you!
