I have two machines that I use with sketchup pro. One is a laptop so that I can sit down with clients, and then I have a desktop with larger screens. I use trimble connect to publish projects as a form of source control so that I can edit files on both machines.
Recently my laptop has been throwing errors. It failes to connect or publish to trimble.
“Uncaught Error: UNAUTHORIZED”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/sketchup-closure-lib.js (514)
[0421/130953.074:INFO:CONSOLE(514)] “Uncaught Error: UNAUTHORIZED”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/sketchup-closure-lib.js (514)
[0421/131025.842:INFO:CONSOLE(514)] “Uncaught Error: UNAUTHORIZED”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/sketchup-closure-lib.js (514)
[0421/131356.670:INFO:CONSOLE(119)] “Initializing Trimble Connect”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/main.js (119)
[0421/131356.870:INFO:CONSOLE(120)] “Failed to initialize Trimble Connect.”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/main.js (120)
[0421/131356.870:INFO:CONSOLE(60)] “ErrorHandler caught:”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/main.js (60)
[0421/131356.870:INFO:CONSOLE(60)] “Error: UNAUTHORIZED”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/main.js (60)
[0421/131356.886:INFO:CONSOLE(514)] “Uncaught TypeError: Cannot read property ‘length’ of undefined”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/sketchup-closure-lib.js (514)
[0421/131404.648:INFO:CONSOLE(514)] “Uncaught Error: UNAUTHORIZED”, source: file:///C:/users/18286/appdata/roaming/sketchup/sketchup%202021/sketchup/plugins/su_trimble_connect/tc_common/client/js/sketchup-closure-lib.js (514)
The following errors are in the log. Is their some type of check out or sync issue with version numbers that is under the covers? I appreciate the simplicity of the trimble connect menu, but it hard to tell what is going on behind the scenes when you click the button and a window pops up for 1/2 second, then crashes and does not provide any kind of modal popup or use feedback. In the debug log the logging is just a sparce a posted above. Can somebody help me understand where the break down is, or how I can turn up logging?
THanks
Chris
