Transition path between slides
  • create interior
  • set scenes each scene for each room
  • create animation without hitting walls !
    ! setting more slides than one for room is not allows (for purpose of recreating this issue)
solutions
  • create more slides to avoid hitting wall (issue - slows down the presentation creates unwanted delays in flow)
  • you suggest ?
feature
simple 2 lines in space one for camera movement one for direction of camera
keypoints you can set keypoints to change camera values (field of view)
all is already in yet it is not
  • you cant edit it to your point of liking - smooth crazy angels of view, no hitting the wall
Motion planning to find shortest path between two scenes that does not touch/intersect entities (walls etc.).
Possibly one of the camera/animation extensions does something similar already.
