how can i imagine this line of code sel_comp.definition.bounds.width * Math.cos(sel_comp.transformation.rotz.degrees)
here sel_comp is the selected component…
I want to know the clear explanation of this code…
sel_comp
the selected component instance link
.definition
the definition of above instance link
.bounds
the bounds of definition link
.width
the width of bound link
multiplication link
Math.cos()
Standard Ruby Math library method to get cos of angle
sel_comp
the selected component instance (as above)
.transformation
the transformation of above instance link
.rotz
not defined in standard SU Ruby API it should be a #def rotz
method in the code somewhere else I guess it will retrieve the rotation angle about Z axis from the instance transformation matrix
.degrees
to convert from degrees to radians. link
Yes correct. But it is actually the Trimble Dynamic Components extension that “monkey patches” the Geom::Transformation
class (as well as many other API classes.)
Certainly you’re right!
Don’t be embarrassed. All those “monkey patches” are still undocumented.
